tom tom3
Discussion in 'Mobile Phones Forum' started by av2diefor, May 20, 2005.
  1. av2diefor
    av2diefor
    Anyone know if tom tom 3 is compatable with Dell X50v/
    Tried it and keeps locking up!
    Also the tom 5 is out soon worth waiting for?
  2. HSC
    HSC
    Nov 23, 2004
    1,979
    63
    Coventry
    +172
    have you checked which version you are running....?
    v3.07 is the latest
  3. av2diefor
    av2diefor
    Yeah, finally got it going.
    I had installed the gps info that came with the cf gps,i just done a hard reset and installed tom tom again and just let the gps on tom tom configure it.
    Works well! :clap:
  4. harmlos
    harmlos
    May 22, 2005
    11
    Gettint Tomtom installed can be an absolute nightmare, i had to install it 5 times on my h4000 pda, i am hoping version 5 will be a lot better, if you can wait then i would as v5 is supposed to fix a lot of the bugs/annoyances in v3, including out of date maps which is really important. It is rumoured to be released at the start of June which is not long now.
  5. av2diefor
    av2diefor
    V5 out soon,it allows 7 digit postcode search!
    More money!!!!!!!!! :suicide:
  6. Jonny1973
    Jonny1973
    Tomtom 5 supports 640x480 screens, full UK post codes, landscape mode and comes pre-installed on a memory card.
    www.totalpda.co.uk have it in stock now!!!
  7. av2diefor
    av2diefor
    Cant find tom tom 5 anywhere as software on the link.
  8. Crocodile
    Crocodile
    Nov 4, 2002
    18,325
    +6,858
    If you V3 is legit then you can upgrade to V5 direct from Tom Tom here.
    Check through the link carefully as some features are also lost in V5.
  9. av2diefor
    av2diefor
  10. ram33
    ram33
    May 28, 2005
    1,150
    48
    +61
