Tom Tom One Mount
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by Henry, May 6, 2007.
  1. Henry
    Henry
    Aug 9, 2000
    2,194
    Hull
    +52
    Just bought a TomTom One Europe (New Edition). Quite happy with it so far, except for the fact that the mount just won't stay on the windscreen for more than a few minutes.
    Any tips or suggestions for a sturdier and more secure replacement mount?
  2. LOFC75
    LOFC75
    Nov 4, 2006
    16
    Mine used to fall off 5 or 6 times a day in my van :thumbsdow
    I cleaned the area on the windscreen with a kitchen towel and problem solved!
  3. criticalmass
    criticalmass
    Feb 28, 2005
    548
    28
    Durham
    +40
    My TTG500 does that all the time, especially when its cold in the morning but i've had it fly off the window several times while i've been driving. Only thing you can do is make sure your window is clean and slightly wet the sucker before putting it to the glass.
    By the way thieves now look for the sucker mark on your windscreen & use that as an invite to pop your window n go looking for your sat nav.
  4. CypRoadster
    CypRoadster
    Dec 24, 2006
    49
    11
    Glenrothes
    Bought one of these, they're :thumbsup: http://cgi.ebay.co.uk/TOMTOM-ONE-V2...6QQihZ007QQcategoryZ75327QQrdZ1QQcmdZViewItem
    The original mount won't stay on unless wet (licked):rolleyes:
  5. Henry
    Henry
    Aug 9, 2000
    2,194
    Hull
    +52
    A bit of licking has made all the difference! Didn't fall off once! I'll stick with my tongue for a while yet then!
