Tokina or Tamron?
Discussion in 'Photography Forums' started by geofftelforduk, Aug 31, 2005.
  1. geofftelforduk
    geofftelforduk
    May 21, 2004
    1,248
    Northern Ireland
    +151
    Guys, need your help again! Sorry!!
    If you where choosing between the following, which would you choose and why?
    Tamron 19-35mm f3.5-4.5 or Tokina 19-35mm f3.5-4.5!!
    Thanks for your help!
  2. seany
    seany
    May 1, 2003
    2,987
    61
    Manchester city
    Looking at the user reviews on Fred Miranda they're evenly matched, i'd go for the tamron myself. But i don't think there's much between them
  3. geofftelforduk
    geofftelforduk
    May 21, 2004
    1,248
    Northern Ireland
    +151
    Seany, thanks for that! Tamron was my gut instinct aswell!
    Do you reckon the Tamron with that range would be a reasonable every day lens?
  4. seany
    seany
    May 1, 2003
    2,987
    61
    Manchester city
    Well it would be close to the classic 50mm at the long end. Which is the standard focal length lens for 35mm slr/full frame dslr shooters.
    I guess it's a little short for an "everyday" lens but thats really depend on what you shoot doesn't it:)
    Bottom line is, at that price you can't really make a mistake
  5. tomson
    tomson
    Jul 19, 2000
    1,918
    Berk'amsted
    +187
    i've been using a 20-40mm for a general everyday lens - I do find it a little bit short but it does the job. You just have to use your legs a little more.
  6. Radiohead
    Radiohead
    Dec 24, 2001
    4,295
    Amazingstoke
    +433
    What's your max budget?
  7. geofftelforduk
    geofftelforduk
    May 21, 2004
    1,248
    Northern Ireland
    +151
    To be honest, either of the two mentioned would really be it cos I want to get something longer in the near future as well, and I dont really have alot too spend!!!
    What are ya thinkin off Radiohead?
  8. Radiohead
    Radiohead
    Dec 24, 2001
    4,295
    Amazingstoke
    +433
    A little more flexible, and an excellent lens, would be the Sigma 18-50mm F2.8 EX DC at around £280 or so. Is that too much?
    Or, you could bite the bullet and go for something like an 18-200 now?
  9. geofftelforduk
    geofftelforduk
    May 21, 2004
    1,248
    Northern Ireland
    +151
    Radiohead! Yeah, I like the idea of a 18-200!! How does the quality of the wide end of the lens compare with a dedicated wide lens like the 19-35mm!!
    What price would you pay for a 18-200mm?
