brymbo76
Established Member
Is there a brush I can buy designed for toilets that can flex all round the U-bend and into the outlet pipe to remove a blockage?
Failing that, is there a liquid I can buy specifically designed to break down faecal matter to remove the the blockage?
Most flexible toilet brushes only go so far into the U-bend. I need one that goes further in and into the outlet pipe as I think the blockage is further in as over a few hours, the water in my toilet, you can start to see a brown colour entering into it further back from the u-bend.
Apart from bleach and toilet cleaner, most drain unblockers I have seen specifically say not to put down a toilet.
Therefore, what would be my best option?
A long toilet brush with flexible shaft that can get as far as the outlet pipe of my toilet?
Or a liquid I can put down there?
Please let me know what would be the best option and please recommend any products you can and where to buy them from.
Many Thanks.
Many Thanks.
