Toggle Buttons on Pronto
Discussion in 'Home Cinema Control & Remote Controls' started by Kevo, Jan 28, 2002.
  1. Kevo
    Kevo
    Aug 23, 2001
    5,448
    Manchester
    +166
    On the AV button om my TV remote you have to toggle through 5 different ones, same for the Aspect ratio.
    Is it possible to limit this number or at least toggle in two directions on the Philips Pronto.
    i.e just have AV1 & AV2 or WS, 4:3 & zoom.
    TIA
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Unless your TV has discrete codes for these modes then no.
    My Sony TV just has one button for the aspect ratio. So I have to cycle through all the modes to get the one I want.
    Best thing to do is set up a button that changes through the cycle to the ratio (or AV input) you want - remember and leave a few seconds delay between commands to make sure they take (my Sony is bad at missing commands for the ratio!).
  3. mjn
    mjn
    May 24, 2001
    23,531
    Herts, England
    +11,932
    regarding the input...on some sony tv's u can assign channel numbers to individual inputs...worked ok for my pronto..
  4. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Cheers mjn :D I forgot about that one :) Must be Monday :D
