markos1
Hi all, scouring recent threads here but also wanted to ask directly regarding a replacement.
My late 2015 Sony 4K KD-43X8307C was reasonably priced back then (£639) but it was infuriating to use as it was so sluggish, to the point you'd select the TV channel you'd want in the morning as you switched it off at night, seriously
. Quite often it wouldn't connect to wifi so cue another 10 mins faffing on a regular basis, so in some ways my 20 month old smashing it isn't quite a bad as it sounds! In essence I think I'm looking for a similar TV to do usual duties (no gaming) so would like:
Any help or info appreciated!
- 4K
- Smart TV with all of iPlayer/ITV hub/All 4/My5/Netflix (previously it wasn't easy to get a full house IIRC)
- NOT SLUGGISH
- 43-50 inches I guess
- Wifi
- Optical connectivity for a sound bar (if native sound is poor)
- Freeview/Youview (what's the EPG deal if it doesn't have one of these?!)
