to tilt or not to tilt
Discussion in 'Plasma TVs' started by happyhiker, Jan 19, 2005.
  1. happyhiker
    happyhiker
    Jan 3, 2005
    421
    +25
    My Plasma arrives tomorrow, but my Wall Bracket is nowhere to be seen.
    I've order a tilting bracket but I'm in half a mind to cancel it and go buy a static mount locally just so I can set things up tomorrow.
    Is a Tilt bracket much better than a Static bracket ? Will I regret it later if I get a static just due to impatience ?
    I'm getting a PW6, view distance about 10.5 feet, it will be above eye level but not as high as above a fire place.
    Anyone advise me on how necessary a tilt is?
  2. geewhizz
    geewhizz
    Jan 2, 2005
    2,403
    +84
    A tilt bracket is only good if your putting it over a door.
    If you are putting it eye level'ish you wont need one,
    save money and just buy a rigid one. :lesson:
  3. garbon
    garbon
    I got a tilt wall mount from av sales via discount on this forum. only £109. i use it tilted screen about 1.3 mtr from floor viewing about 7 ft you can always use it locked flat! I'd wait for it.
    Happy viewing brilliant choice of screen.
