To those who own a Hyundai Imagequest Q321...
M
mmdmmd
I just got mine today. Can you please help me in the following matters?
1: How to see which firmware my TV has?
2: I did an auto scan in iDTV(this is the digital tv mode right?). It picked up nothing, do I need to plug an antenna or something before it works? I am totally new to all these digital TV thing, in fact thanks to the internet, the last time I tune a TV was 7 years ago.
3: On my PC I can only set the LCD TV to 1360 x 768 @60hz. In the TV manual it says it supports 1366 x 768 @ 75hz. How do I make my graphic card out put @ 1366 + 75hz? I have a Geforce 7800 GT 512 Ram dual DVI output.
4: How Do I make games appear in the secondary monitor(LCD TV) without having to mess around with the display properties everytime?
Many Thanks
1: Select idtv in your source menu, then go to menu and select the antenna
symbol, there you wil find factory set, select this and you will see software
version.
2: Do you use an external antenna? Because thats what you need to get
reasonable reception.
3: A program called powerstrip can override the windows settings.
4: I don't know about your videocard, mine does not support two outputs at the same time,
so it's not unusual you have to go through the setting to change
output and resolution.
ps, to show the source menu longer, select menu first and then source.
version.
thank you for your help. The TV i got is version 3.12. Anyone using this version? Does it fixes the clock bug and the lip sync?
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
