to sub or not to sub that is the question
Discussion in 'Subwoofers' started by matmum, Apr 7, 2003.
  1. matmum
    matmum
    Mar 23, 2003
    104
    16
    england
    hi
    i own a pair of ruark cl20 (floorstanding) speakers and i wondered whether or not to use my sub (rel strata III) while listening to music - as i think the speakers are pretty descent sounding as they are - and i dont really wanna create an unnatural deep bass sound that needs adjusting everytime i put a different album on. i just wondered if anyone had any ideas or opinions about this.
    thnx :)
  2. nathan_silly
    nathan_silly
    Depends, if your room is big, then you can use them- dial to around the same frequency as your Ruarks (say 40hz), and set to quite a low volume- not pronounced.
    Probably need to adjust the subwoofer crossover slightly, as the room will effect the Ruark's bass characteristic.
    Suck em and see.
