To split or not to split?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by azz, Jul 4, 2005.
  1. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    Is it better to use a splitter or attach 2 coax cables to the same arial directly?
    I am using the arial for freeview and there are a lot of trees.
    If splitter better why and which one to buy? £1 or £12
    Azz
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Use a splitter, preferably an aerial amplifier with 2 outputs. Never attach two cables to an aerial - it can cause all sorts of problems.
  3. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    Nick do you meen a signal booster in a room that is powerred or an expencive splitter?
    How much should i pay?
    :lesson:
    Azz
  4. hog
    hog
    Jan 15, 2005
    380
    28
    +36
    hi
    i think he means a 2way amp(booster) that is mains powered,that would be best for your situation. cheers ant ps around 10 to 15 pounds probably have them in bnq
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Something like the RT68Y from Maplin for £17.99
  6. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    Nick and others,
    I do not realy want to boost the signal with a powerred splitter; is a non powerred splitter going to be better than attaching 2 coax to a high gain arial and if not what problems am i likley to get if i do have one or the other?
    Azz
  7. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    With a non powered splitter you will lose more than 50% of the signal from the aerial down each cable. If you connect more than one cable to an aerial you can set up "standing waves" within the cables which can actually cause a cancellation effect which could lose you groups of channels.
    Digital channels are broadcast at a much lower power than analogue ones, so it is not advisable to use a non-amplified splitter unless you are in a really strong signal area, and you have already said that you have a problem with lots of trees.
  8. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    Thanks nick,
    No choice except for a standard spiltter.
    What about 2 high gain arials on one pole fed 1 coax each or will each arial interfere with the other?
    Azz
  9. richardys
    richardys
    Jul 19, 2004
    69
    9
    UK
    Why don't you want to use an amplifier? Surely its the best solution.
    If you put another high gain aerial up it won't interfere with the other aerial but it probably won't have the same signal level.
  10. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Two high gain aerials with separate coax feeds would probably work OK, but I can't see why you don't want an amplifier ? It would work out cheaper than 2 aerials.
