To replace a Cyrus 1?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by ronsealdeath, Feb 26, 2003.
  1. ronsealdeath
    ronsealdeath
    My Cyrus 1 has bitten the dust finally and i need to replace it with something with a remote that will cost under £200! Can it be done? will todays amps give me the control, precision and timing of the Cyrus? I was thinking the Marantz pm 4000 or 4200, does anyone have an idea how these will sound compared to the Cyrus? I listen to fast paced punk rock and drum and bass but i love a smooth, controlled sound from my HiFi.
    Marantz CD6000 OSE
    Cyrus 1 (now broken boo hoo)
    Heybrook HB1 speakers (circa 1986!)
    Vivanco Prowire interconnects
    Monster speaker cable
  2. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
    Cheepest good amp with a remote control would probably be the NAD C320BEE (SRP £220). If you can live without the remote ... also take a listen to the Rotel RA01.
    I think these would be nicer / smoother replacement for your Cyrus 1 than the Marantz.
    If you can stretch a little further ... you'll be looking at Arcam A65+, then A75+ along with Rotel RA02, NAD C350 and C370.
    Vikki
  3. Orbital
    Orbital
    Apr 20, 2001
    512
    Midlands
    +4
    Hi There,
    Can thoroughly recommend the Rotel RA-01. I've had mine for about 3 weeks now teamed up with my Cyrus daD7 CD player and they sound superb together. The little Rotel is such a detailed little amp with exceptional timing. I enjoy listening to it more everyday and for the money it really can't be beaten.
    Dave
  4. juboy
    juboy
    If it helps any, I have a mint condition NAD C320 (with remote control!) sitting down in my basement sitting room not even connected to a source... it's a cracking sounding amp. If you wanted to arrange a deal on it, fire away with an offer :)
    I don't have the box but do have an NAD phono stage box (worth £40 or £50) that I'd be happy to throw in for free.
  5. ronsealdeath
    ronsealdeath
    Thanks for the advice, i'm going into my local sevenoaks to try out the Rotel next week, hopefully it will fit the bill.
  6. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
    Probably going to get told off for this ... but if you like the Rotel, I have a RA-1060 for sale...
