Hi folks,
Looking for your expert advice please.
Been quite the journey for me hifi wise and growing my knowledge all the time. However, there is still the mystery of pre and power amps to contend with.
Currently I have:
As I've not had the Audiolab 6000a set-up to separate the pre and power amp in it (and concerned the soldering would be beyond me) I decided to put no load on it to use it as a preamp. With the Rega Maia it was a bit easier. I opened up the box and flicked the switch internally and it's good to go (after I searched the web for ages as the instructions with it are pants).
Questions
I have found the Rega used as a preamp muddier and not as detailed. I was kinda hoping it would come out tops. Can anyone tell me (and I know it's not ideal to mix brands when using pre and power amps) what they think the issue might be?
Think it could be the difference in Gain as the Maia is measured at 27, or such and the Audiolab at what, 18-20? I'd be grateful for your thoughts.
Also the Audiolad Power Amp hums. Not too audible (you have to be up close) and you can't hear it through the speakers. Is this normal? I've read various reviews saying either it shoudl be totally silent, or it does hum?? Opened it up and all looks tight inside and no signs of any burning etc.
Any ideas?
Many thanks,
A
Currently I have:
Monitor Audio MR6s (bi-wired)
Beresford Caiman SEG DAC (upgraded). Not using it as a preamp.
(System 1)Audiolab 6000A Integrated Amp (refurbed), but using as a preamp/selector with no speakers attached
Rega Planet CD player or
(System 2)Rega Maia Amp (Integrated), but using as a preamp/selector with no speakers attached (flicked the small DIN switch inside to enable this)
Rega Planet CD player and
(System 1 or 2) Audiolab 8000P Power Amp (speakers attached to this only)
I was fairly happy with the sound (on either amp...perhaps the Rega more than the Audiolab) before I added the power amp, but wanted to get a 'true' separates system, so wondered what improvements could be found. I'm looking to have just one system, not two and sell what I don't need/doesn't work for me.As I've not had the Audiolab 6000a set-up to separate the pre and power amp in it (and concerned the soldering would be beyond me) I decided to put no load on it to use it as a preamp. With the Rega Maia it was a bit easier. I opened up the box and flicked the switch internally and it's good to go (after I searched the web for ages as the instructions with it are pants).
Questions
Any ideas?
Many thanks,
A
