To pre-cut??
Discussion in 'Cables & Switches' started by Les E, Oct 28, 2004.
  1. Les E
    Les E
    Oct 5, 2004
    963
    St. Helens
    +18
    I am having a debate (mainly with myself or the wife...but she doesn't have a choice listening!! :laugh: ) of what would be the best option with regards to pre-wiring speaker cable before plastering.
    Should I have the cabling pre-cut and terminated, which would mean some 'exact' measuring. or should I have the cabling laid then terminate after the plaster work is complete.
    I really do not know the best way to go with this...anyone??? :confused:
