F
Feersum enjinn
Okay i am wondering if there is a cheap option to handle all this ...
Room 1 living room -
Digital box - 1 x Scart and 1 x serial out option
Video recorder - 1 x scart out option
DvD player - 1 x scart and 1 x s-Vid out option
Homechoice special TV box - 1 x scart out option
Terrestial TV aerial
All sources need to be fed out to three sources.
The (1) TV and the (2) projector in the same room. I dont mind swapping over one cable between TV and Projector though.
Then the second (3) TV in my bedroom.
I want to do this fairly cheapily,
My questions are :-
(1) Will a Prov do this?
(2) I need to change channels from my bedroom. Any advice on cheap/workable remote control/infa red signal transferers.
Thanks in you can help!
My questions are :-
