To go with Kef Centre and Sub. Eggs?
Discussion in 'Home Cinema Speakers' started by Talheedin, Apr 28, 2005.
  1. Talheedin
    Talheedin
    Dec 21, 2004
    16
    Hi All,
    I'm slowly trying to update my speakers due to small fingers wear and tear. I've already got a kef sub and Q6 centre and was going to get eggs to replace the front and rear warfdales (modulus or something, I forget) but from what I've read on this forum you're not too impressed with them.
    What would you recomend, bearing in mind that they need to be wall mounted and fairly descrete (the wife is not too happy with the big black boxes sticking out everywhere), sound good with the two existing kef speakers and fit within a tight budget (small fingers wear and tear on the bank balance too I'm afraid).
  2. Unlight
    Unlight
    Jan 6, 2003
    1,484
    38
    Belfast
    +9
    I personally feel the KEF eggs are still very worthy. In fact, I auditioned them alongside some of the Mordaunt Short Genie that everyone has been raving about, and found the Eggs to sound far more coherant with better bass integration.
    If you can find a couple cheap, I would highly recommend the eggs especially since they would sound similar to your centre speaker. Maybe look at the KEF Q1's instead, although they are a bit boxy in comparison.
  3. t0by
    t0by
    Jul 27, 2004
    455
    Hertfordshire
    +7
    I would echo Unlight's comments re. the Eggs. I have had a set for a good while now and I think they are great. Give them a try alongside some of the competition and see what you think!
  4. Talheedin
    Talheedin
    Dec 21, 2004
    16
    Thanks for that, I will give them a try.
    Do you know where the cheapest place to get them is? I've seen them in Superfi for £100 each.
    Also, is there a difference with the ones that come with the 2001 set and those from the 2005 set?
  5. stu mcc
    stu mcc
    Nov 13, 2004
    618
    28
    +28
    have you also considered KEF's custom install speakers mounted in the wall? Depending on the models you should be able to get 4 for about the same as the eggs.
    stu
  6. jagr
    jagr
    Apr 6, 2003
    1,400
    Cheshire
    +115
    Superfi are doing the Kef Qcompacts for £150 a pair at the moment.
