To all those with HomeCinema AV setups & SPL meters: Post your dB levels here.
Discussion in 'Home Cinema Speakers' started by tk2001, Jan 26, 2002.
  1. tk2001
    tk2001
    Nov 4, 2001
    1,402
    48
    +36
    I've finally managed to calibrate my dB levels for each of my speakers to 85dB using a digital RadioShack SPL meter - the meter is set to 'C-Weighting' with the respone set to 'Slow' - and here are my complete dB settings for each speaker:
    Front L: +12dB
    Front C: +12dB
    Front R: +12dB
    Rear L: +11dB
    Rear R: +09dB
    Subwoofer: -05dB
    Does anyone else have similar settings to mine?
    Please posts your settings here because it would be interesting to see how each setting differs from one another.
  2. Jase
    Jase
    Mar 16, 2001
    10,723
    United Kingdom
    +2,497
    I´ve set mine to 75db. Meter set to C-Weighting, Slow response. Using the AVIA setup disc.
    FL: 0db
    FR: 0db
    C: 0db
    SL: -3db
    SR: -3db
    SB: -6db
    SUB: -8db
    Readings will depend on Speaker Sensitivity, impedance etc and the equipment people have.
    If they were set to 85db they´d all be 10db higher, so tk2001, yours are ok. As long as they are all balanced in relation to each other.
    cheers
