We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
To all Philips 37PF5520D owners...
Discussion in 'Philips TVs Forum' started by HCK, Oct 30, 2005.
Tags:
  1. HCK
    HCK
    Oct 21, 2002
    784
    46
    West Yorkshire
    +129
    I am seriously considering getting this model and would like your views please. I have read the HCC review and wonder if its as bad with SD as they make out ? I have telewest and use a PACE digibox, would SD be ok with this in your opinion ? Does DVD with RGB fair any better ?
    I would like to know its capability with SD as I have already seen it with HD and it looks great.
    Cheers.
  2. PeteZahut
    PeteZahut
    Oct 20, 2005
    74
    +9
    Where is this review that you speak of ? Do you have a link ?
    I have this TV and whilst SD is not as good as CRT , it is okay. Make sure that you connect through the RGB scart socket and have the settings for RGB. Also, make sure that the sharpness is set low to 2-3. Made mistake when first got it of having it set v.high and the PQ was horrible.
  3. HCK
    HCK
    Oct 21, 2002
    784
    46
    West Yorkshire
    +129
    i think it was in the november HCC issue, my boss has got the magazine. It reviewed the Philips, JVC 37DS6FJ, whch was excellent...and a panasonic.
  4. technics100
    technics100
    I have just bought the 32pf5320, I think its the same apart from the 5520 has a freeview tuner built in. I am using it with ntl. I think the picture quality is good enough as long as you aren't too close to the screen..
  5. HCK
    HCK
    Oct 21, 2002
    784
    46
    West Yorkshire
    +129
    anybody else got one ?
  6. vegasgo
    vegasgo
    Jul 16, 2005
  7. scottwb
    scottwb
    I'm using mine with Sky+. Generally pleased as long as you don't get too close, I'm about 8 feet from the tele.
    DVD wise - it's excellent.
