To all 3803 owners
Discussion in 'AV Receivers & Amplifiers' started by jbwingnut, Mar 25, 2003.
  1. jbwingnut
    jbwingnut
    Have any of you set up the 3803 so the main front speakers are bi-amped using the spare rear surrounds?
    If so, is there a marked improvement? Was it easy to set-up and how did you do it?
    John
  2. juboy
    juboy
    I don't own it but am fairly sure that, according to the 3 mag reviews I've read, this facility isn't a feature of the 3803.
  3. jbwingnut
    jbwingnut
    I read in a previous thread that if the main speaker outputs are connected to an un-used input and then assigned in some way it can be done. I can't find that thread now, that's why I'm going over old ground. I have one of these on order with Unbeatable and I should hopefully get it within a week if their timescales are correct.
    John
  4. DJP
    DJP
    Jan 10, 2003
    74
    Hampshire, UK
    +5
    Although I have a Denon 3803 I haven't tried this.
    If I remember correctly the thread you were refering to was regarding 3802 amps. I believe that the solution was to use the back speaker outputs as multi-zone and ensure that the multi-zone source was the same as the main source.
    Of the top of my head I can't see why you couldn't do this with a 3803 as well. However, in doing so you would lose the option of 6.1/7.1 surround which is why I haven't done it. :)
    Hope this helps.
    Derek
