phresh
Established Member
I just want to know what size threaded bar other people have used, or at least think will work for this stand.
The original design uses 18mm rods which I cannot find anywhere, although I can find 16mm and 20mm. What I really want to know is if the 16mm rods will be strong enough (1000mm high btw)?
Obviously its cheaper too, I can get the 16mm rods,nuts and washers for less than £15 whereas the 20mm stuff comes out at closer to £30.
I have 1 more question and thats regarding turntables on this stand. What I am thinking of doing is instead of placing the turntable directly on the top shelf, is to mount another shelf directly onto the top shelf using spikes or something similar. Any ideas?
Thanks in advance....
