Tmreq
Discussion in 'TAG McLaren Audio Owners' Forum' started by johnson, May 14, 2004.
  1. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    Can TMREQ be used in Direct mode? ie; for 2 channel
    Regards
  2. PhilB1234
    PhilB1234
    As far as I understand it TMREQ is applied to each channel prior to output after decoding, irrespective of format, so you will get the advantage with every sound mode, even mono!
    Personally, I found the Direct mode the easiest to hear the improvements in, maybe because we know CD soundtracks better.
    I seem to remember a Gramophone magazine review of the AV32DP singing the praises of the processor in 2 channel mode because of the TMREQ benefits......
    Hope that helps!
  3. Teejoo
    Teejoo
    Apr 24, 2004
    221
    The Netherlands
    +3
    Yep,
    Phil is correct.
