TMPGEnc DVD Author
Discussion in 'Blu-ray & DVD Players & Recorders' started by jem, Jan 14, 2004.
  1. jem
    jem
    Sep 24, 2002
    527
    +7
    My son is using the above software to edit stuff recorded from his E50. He's copied the file across OK and can work with it to edit out adverts etc. However as he's working with some music video the sound would be quite helpful so he can see where to divide it up - however there doesn't seem to be an option for sound, or alt least he can't find it!
    Can anyone help?
  2. danny-p
    danny-p
    Is it the free months download?
    Thats the one i have and mine is the same....Maybe they enable it when you buy the full version.
    Danny
  3. jem
    jem
    Sep 24, 2002
    527
    +7
    No, it's the full version.
  4. danny-p
    danny-p
    Strange.....Maybe you have to configure it somehow with your sound card.....
    Seeing as its still unselectable on your full version i'm gonna have a play about with the settings on mine to try and get it to work....
    I'l keep you posted.
    Danny-p
  5. jem
    jem
    Sep 24, 2002
    527
    +7
    Thanks. Will let you know if we turn up anything.
  6. nwgarratt
    nwgarratt
    May 5, 2002
    27,208
    +3,046
    DVD Author doesn't have audio preview. You get the video in the edit clip part but no audio.
    How about using the divide on the recorder, then DVD Author will see the separated parts.
  7. jem
    jem
    Sep 24, 2002
    527
    +7
    That solves the mystery - thanks. We'll try the divide option on the recorder.
