Tmpg Help
Discussion in 'Blu-ray & DVD Players & Recorders' started by SIP, Sep 9, 2004.
  1. SIP
    SIP
    Aug 10, 2003
    132
    NORTH YORKS COAST
    +3
    Sorry if this has been asked before.
    I recorded a Film from tv last week onto RAM, then used TMPG to convert it to a dvd file.....no problems.
    I did the same again last night, using the same disc, but when I put it through TMPG, I get the message "Illegal video file....you can only use Mpeg1 video or Mpeg2 video". Seems strange, I have done nothing different to what I normally do, and have not had this message before.....Any suggestions.
  2. Kevo
    Kevo
    Aug 23, 2001
    5,364
    Manchester
    +146
    I had a similar problem and before anyone says, it doesn't matter if you have your recorder set to 'fixed' or 'auto' resolution (if you have a pan machine). Should make no difference, althogh 'fixed' is generally the better option.
    Sometimes afte a reboot it would eventually accept the disk.
    Now TMPG just doesn't like anything I give it so I gave up on it.
    I now use Ulead Video Studio or DVD Workshop to import from RAM with no problems.
    You can download a trial version from www.ulead.com or there may be alternative software that will convert VRO.
    DON'T just simply rename it to a mpg file either. This can cause problems with some software and most certainly with TMP.
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,240
    Warwick
    +2,282
    Copy the file onto your HDD and then try importing it. If you still don't have any luck very carefully clean the DVD-RAM disk as this could be what is causing your problem. If all else fails then try importing into TMPG 3Xpress.
  4. SIP
    SIP
    Aug 10, 2003
    132
    NORTH YORKS COAST
    +3
    Thanks Kevo
    When I have had the message "mixed video format" from TMPG, I have re-recorded and changed the settings to "fixed" on the panny. But I have never had this message before - and I dont see how changing the VBR causes the file to be changed.
    I will follow your advice and try the unlead product. Does it differ vastly from TMPG?
  5. SIP
    SIP
    Aug 10, 2003
    132
    NORTH YORKS COAST
    +3
    Thanks also Rasczak
    I will also follow your advice on transfering to HDD.
    TMPG is such a good product in many ways, but it aint half picky!!
    BTW - Does anyone know if the Unlead product causes the picture to pause slightly if you edit with it, like TMPG does.
    Thanks again
