TmpEnc Template
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Loafer316, Jul 6, 2003.
  1. Loafer316
    Loafer316
    Apr 8, 2003
    330
    Hi guys i have a Sony Pc100E dv camcorder. I'm using Pinnacle Studio 8 to capture.
    I tried Tmpenc with settings found on dvdrhelp.com to make a PAL dvd compliant mpeg2. However the resulting file has jerky movements with quick left/right pans. I thought it could be a interlace problem so i swapped the settings of bottom field to top field but the results were the same.
    I tried rendering the file using studio 8 and that came out fine.
    Can anyone mail me a tmpenc template they use to get good results to make a DV capture to DVD mpeg2 ?
    thxs for the help.:smashin:
  2. Loafer316
    Loafer316
    Apr 8, 2003
    330
    any suggestions of what i might be doing wrong?:zonked:
  3. liam_b
    liam_b
    Apr 24, 2002
    390
    28
    Wilds of north Leicestershire
    +25
    Er yes and no!
    Sorry had to do that, expanding further, if I import via firewire to a DV-AVI file using Ulead Video Studio 7 then edit + save out a DV-AVI file that file shows the jagged vertical edges if I watch it on the PC. After I then use TMPPEnc+ to make a DVD MPEG2 it looks great on the TV and on the PC too.
    So are you getting the "jaggies" on the PC or the TV?
  4. Loafer316
    Loafer316
    Apr 8, 2003
    330
    on the PC...havn't tried on tv yet. :(
  5. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    If you want to understand & get the best out of TMPGEnc then check out Rui's Guide
  6. Loafer316
    Loafer316
    Apr 8, 2003
    330
    thanks m8...i followed this to the exact specs the 1st time....anyway i'll try again with different footage....thks for the help guys:smashin:
