TMA 100x5 Software Level
Discussion in 'TAG McLaren Audio Owners' Forum' started by AMCross, Feb 19, 2005.
  1. AMCross
    AMCross
    Dec 3, 2003
    6,018
    Livingston,Scotland
    +208
    Hi how can i tell which software version is installed in my newly purchased amp :rotfl:
    and if it needs an update how do i do it none of the manuals i have pdf's say anything about HOW to update the software
    Thanks Adrian
  2. Teejoo
    Teejoo
    Apr 24, 2004
    221
    The Netherlands
    +3
    Hi, I believe you can see it in the av's tagtronic menu.
    To update the amp:
    - turn power off and un-plug (!) the amp
    - connect the Tagtronic lead
    - plug-in the amp and power it up (LEDS stay off)
    - start upgrade wizzard
    - the amp restarts after software install
    Theo
  3. AMCross
    AMCross
    Dec 3, 2003
    6,018
    Livingston,Scotland
    +208
    Thanks for that i will be picking it up tommorrow :clap:
  4. sijones
    sijones
    Nov 5, 2001
    632
    Reading
    +34
    Did you find a silver 100x5r or did you settle for one in black?
    Regards,
    Steve
  5. AMCross
    AMCross
    Dec 3, 2003
    6,018
    Livingston,Scotland
    +208
    silver and now to find another :smashin:
  6. AMCross
    AMCross
    Dec 3, 2003
    6,018
    Livingston,Scotland
    +208
    Cannot get AV32R to communicate with amp :thumbsdow
    The AV32R will not reconize the amplifier in TAGtronic bus setup but will power the amplifier and DVD32FLR down :eek:
    Updated to latest software but still the same :confused:
  7. Polecatpete
    Polecatpete
    May 12, 2004
    476
    +5
    Have you check the id of the amp? I can't remember how you change it but there was a post on this a week or so back...
