TM13U X10 RF Radio Receiver
Discussion in 'Home Cinema Control & Remote Controls' started by milanlad, Jan 13, 2004.
  1. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    I'm considering using multiple TM13U RF to X-10 module to extend the range of the RF pick-up.
    As I understand it the built-in appliance module is always set to address 1. I pressume this to be address A1. Does this mean that if I have multiple TM13U receiver modules, the built-in modules will all go on or off when A1 is used?
    Is it not possible to change the address of the TM13U modules so that they can be triggered and used independently?
  2. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
    I have experimented with my X10 system, and it seems there is no way of changing the unit code. This is anoying, because the switching facility on the TM13 is totally wasted, because of this.
    If you change the address on the TM13, the other X10 modules will have to be on the same - so there's no way round it.
