TM AV32R add ons £££
Discussion in 'AV Receivers & Amplifiers' started by BadAss, Nov 30, 2001.
  1. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    Just recieved a reply from TM as to when the DTS discrete upgrade will be available and how much it will cost. This is what they said "To upgrade your unit to include DTS-ES Discrete and Neo:6, will require a simple option code, similar to the Pro Logic II option code." And this comes in a price of £99, plus Ill have to buy the cable to download the new operating software to 3.5 at £70 cheap, I think not. Then I need a new amp to power the two channels. £200+ and speakers £200+ Not forgeting some sofware say 5 DTS 6.1 DVD's at £17=£85 That makes a grand total of £655. All this and I've just told the Misses I'm not going to spend any more money on my HC. I hope I don't go to hell for this...
  2. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    19,459
    Inbetween Upgrades !
    +7,736
    Hey Badass,
    I also live in EP , sorry to be personal , just thought i,d mention it !
    Kev
  3. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    Nice one. What school did you go too?
    Wierd, my name is Kev also.
  4. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    At least you get the option of adding future upgrades to Tag's kit, unlike every other AV company.
    You don't have to get the Tag Tronic Programming cable, just take your amp to your dealer and they will upgrade it for you :)
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Let the Tag dealer do it all for you and extra amp channels for the rear don't need to be super high quality (secondhand stereo?), it is the L, R and C that are important IMHO and you are not changing those. It will not be as expensive as you think. 7.1 is sooo much better than 5.1, the only discenters are those with 5.1;)
