TIVX 5100SH Repairer
Discussion in 'Video Streaming Boxes & Services' started by MattyHerts, Jun 15, 2009.
  1. MattyHerts
    MattyHerts
    Feb 20, 2006
    45
    I have a 5100SH and for a while now the front display has gone blank.
    Does anyone know of a repairer that would be able to look at the problem?
    Many Thanks
    Matt
  2. j4ck100
    j4ck100
    Jun 17, 2009
    884
    28
    Berkshire
    +43
    Where abouts does it need to be??
  3. MattyHerts
    MattyHerts
    Feb 20, 2006
    45
    I'm located in Hertfordshire but open to anywhere so I can get it fixed.
  4. happyuser
    happyuser
    Nov 17, 2007
    81
    +8
    Did the display gradually fade over a period of weeks?,
    or,
    just disappear?
    If the latter, and your up for it,
    would be worth opening up the 5100 to see if a lead to the
    display is no longer correctly connected.
  5. MattyHerts
    MattyHerts
    Feb 20, 2006
    45
    I think it just disappeared one day did try looking inside but couldn't work out how to get to the display bit, any help advice greatly appreciated!
    Matt
