TiVo
Discussion in 'Digital TV & Video Players & Recorders' started by pwiles1968, Sep 11, 2003.
Tags:
  1. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +10
    How Does TiVo Decode Sky, is it a direct replacement for your sky box? If so can it record while watching another channel?
  2. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    It doesn't decode it. That's down to your Sky Box. TiVo only has a terrestrial tuner (not digital) so it just acts in the same way as your old VCR (except it's digital).
    No, you cannot record whilst watching another channel but you can record whilst watching a pre-recorded programme off the HDD.
  3. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +10
    No Massive benefit over a DVD recorder then (other than cost at the moment)? I know about the planner stuff if you subscribe, but I watch Sky mainly so I would Have to program the sky box to switch channels if I want to record while I am out and we all know how good the personal planner is, you are lucky if it switches over on the right day let alone at the right time!
  4. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    Huh? No, you do not have to set the Sky box. The TiVo controls the Sky channel switching etc through the IR emitter. You have to do nthing other than set your season passes, recordings etc on the TiVo and it does the rest. Once you get TiVo ALL control of your sky box is now done via TiVo either automatically or using the TiVo remote.
    believe me, if you get one you will see what all the fuss is about and I'll guarantee you will not go back. If you don't like it I'll buy it from you.
    May I suggest you get along to the TiVo site and take a look at the demo. Comparing TiVo to a plain DVD recorder is like comparing apples with oranges.
  5. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +10
    Oh that’s better, when you said "so it just acts in the same way as your old VCR" I assumed it was a dumb drive, well may be worth a look not sure about £200 pounds for a second hand one + £200 for the subscription don’t think I record enough to warrant that much, but will have a think anyway.
    Thanks for the info.
  6. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    Yeah sorry. NOt owned or used a VCR for over 10 years so assumed they control the digital boxes now automatically. I guess not then. TiVo has so many other benefits that makes it the best piece of A/V kit I have ever owned. And I've bought lots of kit :)
  7. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +10
    Can I use it like a VCR without subscribing, if I set time/date to record and the Sky channel number will it switch the Sky over automatically?
  8. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    No, (you can set it manually but it won't control the Sky box) but to be honest, without the subscription you lose all the great functionality so then it really is just a digital VCR. Wouldn't recommend that. You'd be better off with something like a Pace Twin.
    TiVo lives or dies by it's subscription (fortunately or unfortunately)
  9. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    I'm not sure if that is true. I have never used an unsub'ed TiVo, but I think the IR database is still accessed and therefore will control the digibox. Obviously if a new box is released you will not get any updates to the IR database and will therefore be unable to control it.
    Mark.
  10. bop
    bop
    what sky package do you have?
    i've heard that sky have scrapped the ten pound monthly sub for sky+ if you subscribe to 2 or more premium channels.
    in which case irs just 250 pounds for the new digibox ad thats it..
    you will then be ABLE TO RECORD ONE CHANNEL WHILE WATCHING ANOTHER..
  11. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    nd soon record two channels at once:)
  12. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    it's actually only £200 fitted until the end of the month.
  13. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +10
    I only Have the Family Pack, What does the new £50 install fee for Sky+ include? is it just unpack it from the box it is in and connect the cables? If so complete rip off.
  14. uczmeg
    uczmeg
    May 18, 2003
    3,154
    71
    Nottingham
    +45
    It is still a £1 to install isn't it? It was yesterday.
    If you aren't moving your old box to another room then it is practically an unpack and plug in, plus a phone call to activate.
    If you are moving your box then you get a 2nd LNB and all the work required to wire up the second box.
    MArc
  15. xyznicko
    xyznicko
    The LNB has to be changed to a quad output one, whether you are moving digiboxes or not.
  16. sanderton
    sanderton
    Yes, it will. But you'll want a sub, even if you don';t think you do now! :)
  17. sanderton
    sanderton
    All Sky boxes use the same IR codes.
