So after many years of non use I've dusted down a scart cable as I want to preserve some 1080P Champions League footage currently residing on an old Tivo box that I'm hoping to replace (and so lose the recordings). I want to record the footage from the tivo in the best possible analogue quality (i.e. XP) via the AV2 on the Panny. The Panasonic instructions seem to say you can choose between XP/SP/EP/LP but when I select AV2 and press "record" all I get is the choice between 30 mins recording or continous. The footage then records in SP mode. There isn't any option to force it to record in XP. The original source footage is in glorious 1080P and doesn't look that great in SP mode, I'm not sure XP will be a whole lot better but I want to at least try. Thanks.
