Tivo Remote issue
Discussion in 'Digital TV & Video Players & Recorders' started by caleb2002, Jun 7, 2004.
Tags:
  1. caleb2002
    caleb2002
    Hello, I have a Tivo and have recently put it in my main room (previously it was in another room by way of an ir extender and some cables).
    Since putting it on top of my telly (a Tosh 50wt29b) the TV remote doesnt work now and then.
    The ir commands seem to be getting all mixed up or something, because also now my tv remote seems to be causing certain functions on my Yamada DVD player to go on.
    This doesnt happen every time but when it does its as though the commands getting delayed by half a minute, but that is on both the Tosh remote and the tivo remote.
    Has anyone had this before?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,405
    Rainham Essex
    +2,452
    If you think the problem is with the TiVo remote then set it to one of the other sets of RF codes to see if that helps.
    Also make sure that you don't have any other remotes in the room with a mag etc on them that could be pressing a button.
    Mark.
