TiVo Remote code for AV32R
Discussion in 'TAG McLaren Audio Owners' Forum' started by cbemoore, Aug 1, 2004.
  1. cbemoore
    cbemoore
    May 16, 2002
    1,225
    38
    Esher
    +16
    Hi guys,
    My first post in the Tag forums, so be gentle! :)
    I'm trying to program my TiVo remote to control the volume on my Tag AV32R. But the Tag isn't mentioned in the TiVo's list of remote codes.
    Does anyone know what code I should use? Or does TAG use the same remote commands as another manufacturer?
    Chris
  2. cbemoore
    cbemoore
    May 16, 2002
    1,225
    38
    Esher
    +16
    Can anyone help? Or am I the only Tag owner with a Tivo?? :eek:
    Chris
  3. Plump
    Plump
    Feb 22, 2002
    636
    19
    under the bridge
    I think Nic Rhodes has one of those but I am not sure if he still reads this forum and if he's using TiVo and TAG in in the same setup
  4. sijones
    sijones
    Nov 5, 2001
    595
    Reading
    +34
    I think the RC5 codes used for Vol+ and Vol- on your TAG AV32R are also the same on Meridian equipment. It is therefore worth checking to see if the TIVO remote can control the volume on a Meridian processor.
    Regards,
    Steve
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,276
    Still here, had a dead PC so I have been quiet recently :( I have a TIVO and Tag but unforunately for you the are in different room! Sorry I can't help with this one
  6. cbemoore
    cbemoore
    May 16, 2002
    1,225
    38
    Esher
    +16
    Thanks for replying, Nic.
    For those who don't know, the TiVo remotes were all preprogrammed with controls for a number of A/V systems and TV's. But unfortunately the remotes can't be updated, so TiVo users are stuck with the following codes that TiVo chose originally:
    http://www.tivobugs.co.uk/RemoteCodes.htm
    I've been through just about all the codes in this list, and none of them seem to control my AV32R. So I guess I'm stuck with juggling 2 remotes......
    Chris
  7. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Don't suppose you would consider a Pronto? It makes for a neater coffee table :)
  8. r21442
    r21442
    Dec 9, 2004
    149
    Glasgow
    In case anyone is still searching 10 years later vis a vis Virgin Tivo box then I got the remote to work fine using the 'How do I customise my TiVo remote to control my AV devices?' and using the search feature - got the code about 10 clicks in.
  9. orange55
    orange55
    Feb 27, 2006
    603
    46
    London
    +167
    I think that is what 10 years does to technology. :clap:
