Tivo question
Discussion in 'Digital TV & Video Players & Recorders' started by CARLOS, Oct 26, 2003.
Tags:
  1. CARLOS
    CARLOS
    Feb 11, 2001
    5,927
    WEST MIDLANDS
    +1,208
    I noticed doing a search, That someone mentioned you can buy bigger HD`s that are already fomatted and setup to fit in the Tivo.
    Anyone know where from ?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    www.pacelink.co.uk
    TiVo Hard Drive 120Gb - FREE Torx T10 screwdriver £ 116.33inc
    Mark.
  3. DaveP
    DaveP
    It's so easy to do it yourself and you get to save £50!
    If you've a PC of course!
    Plus you can keep all your wish lists and recordings!
    Dave
  4. blindlemon
    blindlemon
    They are also available via eBay. A regular poster on the tivo community forums 6022Tivo (not me and no connection, BTW) is a respected vendor.
    All the info you need to do the upgrade yourself can be found on that forum - and, yes, if you have a PC it really is pretty easy. I've done both my TiVo's now, with no problems.
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    I did my upgrade myself and found it very easy. The only difficaulty I found was getting a PC with FAT32 HDD to perform the upgrade as I have WinXP with NTFS and you can not do the upgrade with that :lesson: . If you know your way around the inside of a PC then I would also suggest giving it a go.
    Mark.
  6. CARLOS
    CARLOS
    Feb 11, 2001
    5,927
    WEST MIDLANDS
    +1,208
    Thanks very much for the replies :smashin:
    If i feel brave i may have a go myself ;)
