Tivo Q's
Discussion in 'Digital TV & Video Players & Recorders' started by GadgetObsessed, Dec 27, 2001.
Tags:
  1. GadgetObsessed
    GadgetObsessed
    Jul 6, 2001
    2,397
    116
    +1,102
    Does Tivo support SmartLink? (i.e. set a timer on an IDTV to trigger recording of a certain digital channel.)
    If it does not, is Tivo effectively useless with the Sony NX100 IDTV I am planning on buying?
    Second question, do I have to plug Tivo into the phone line every night or can I just do this a couple of times a week. (Nearest phone socket is a long way from the Tivo.)
  2. Rob
    Rob
    Jul 17, 2000
    1,286
    Norwich
    +35
    Gary,
    Probably you're best bet would be to phone the Tivo helpline. 08702 418486 or go to www.uk.tivo.com. Don't know about the smartlink query, but with regard to the phone point,I would have thought you would always need to be connected. They helped me overcome a couple of initial problems.
    Regards Rob.
