Tivo - Panasonic projector cabling help required!
Discussion in 'Cables & Switches' started by Big Sy, Oct 9, 2004.
  1. Big Sy
    Big Sy
    Oct 9, 2004
    7
    I have recently bought a Panasonic PT-AE100 projector, which is excellent. I currently have a Tivo set up to view my Sky through - and I ned advice on the best way to connect the two. I can use either S-Video or Component cables to connect the Projector to my DVD, but I wanted to be able to watch Sky sports or movies on the big screen too - how best to do this?
    The Tivo outputs are all scart of course and the Panasonic sky box I have doesn't have an s-video output either.
    All help much appreciated!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  3. Big Sy
    Big Sy
    Oct 9, 2004
    7
    Many thanks for that, I am trying to keep the costs down at the mo, where do suggest getting a 2nd hand one?
    Also would a Scart to S-Video cable direct from the Tivo to the Projector not do the job?
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,438
    Rainham Essex
    +2,470
    No, because TiVo does not output S-Video. It only outputs composite (avoid at all costs) and RGB. If you need any other signal type then you will need to convert the RGB signal with the JS-Tech boxes recommended by HD. I've been useing the JS-Tech converters since I got my plasma about 2 years ago and can highly recommend them. Although not the cheapest, they are the best.
    You can get RGB to VGA, RGB to S-Video or RGB to YUV component depending on the inputs on your PJ. Check the specs of your PJ as if it has a VGA input then you may be able to use a Scart to VGA cable if the VGA input can accept RGBS (sync on composite) as this is the version of RGB output from the scart socket on a TiVo and most STB's.
    Keep a look at the Hardware Classifieds forum on here as the boxes do crop up S/H at fairly regular intervals.
    Mark.
