Tivo newbie question - RGB or CVBS?
Discussion in 'Digital TV & Video Players & Recorders' started by Dr Bob, Feb 21, 2002.
Tags:
  1. Dr Bob
    Dr Bob
    After all of the positive posts the temptation was too much - I'm now a TiVo junkie, lifetime sub, planning the upgrade when my credit card cools down a bit.
    Just a quick question though - when I'm watching the digibox via TiVo, either live or delayed then the signal is CVBS. If I switch to Aux bypass it changes to RGB. Is this correct?
    Bob
  2. xyznicko2577
    xyznicko2577
    No you can have RGB from both, you have to check your settings in the menus you need "Video output to TV" set to RGB + Pal and if you're on Software version 1.5** a re-boot of the Tivo is sometimes neccessary to enable the RGB.
  3. richard plumb
    richard plumb
    Jan 27, 2002
    14,513
    Windsor
    +1,053
    and give tivo customer services a ring to get on the 'priority'list for upgrading to v2.5.5 - it is fantastic
  4. Dr Bob
    Dr Bob
    Thanks for both replies. TiVo restarted itself last night after the initial upgrade so I've got now got RGB.
    I'm also on the upgrade priority list.
    Cheers,
    Bob
