Tivo/DVD recorders
Discussion in 'Digital TV & Video Players & Recorders' started by clive joy, Dec 12, 2002.
Tags:
  1. clive joy
    clive joy
    Hi All
    My first post, so be gentle
    What would you recomend Tivo or Panny DVR Recorder. The 'time skip' functions looks pretty goodon the Panny.
    thanks
  2. philipb
    philipb
    Mar 6, 2002
    2,126
    63
    Swindon
    +178
    If you really have to choose, then probably the Panny (if you mean the HS2. If you mean the E30 it's a lot less clear).
    I have TIVO and an E30 - all the functionality and flexibility of the TIVO with its hard disc recording facility, then archive onto DVD using the E30. You can't get close to the TIVOs features with just a DVD recorder - not even the HS2. But personally I think a DVD recorder is now a must have and you might find it very difficult to locate a TIVO for sale. The range of PVRs is growing all the time and new ones are promised for early 2003. Thomson, maker of TIVO, is bringing one out I think which is a combined hard disc/DVD recorder which may be a serious contender.
  3. clive joy
    clive joy
    Thanks Phil
    Panny it is then
