tivo changing channels.
Discussion in 'Digital TV & Video Players & Recorders' started by thfccambs, Dec 19, 2002.
Tags:
  1. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,898
    i am having a problem where my tivo will not change the channel on my panny sky box,so the only thing that is getting recorded is the channel the tv is on.if im watching tv it will come up tivo wants to change channel to record such & such i press select for yes then nothing happens it will stay on same channel.
    cheers,:confused:
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,353
    Rainham Essex
    +2,441
    The TiVo forum recommend that ALL $ky boxes work best with PACE 20010 (without Sky key) or 20017 (with Sky key).
    This seems to work best for most the users.
    Good luck.
    Mark.
  3. Craig B
    Craig B
    There have also been many stories of stray IR causing interference, check there is not a remote control with a button stuck on nearby.
    It is also recommended to only use _either_ the front IR blaster _or 1_ of the wired emitters.
    Best of luck
  4. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,898
    sorted now.
    cheers:D
