TIvo and RGB
Discussion in 'Digital TV & Video Players & Recorders' started by dochall, Oct 11, 2001.
Tags:
  1. dochall
    dochall
    I think the answer is yes but....
    If if purchase a TIVO I believe it's an RGB scart. I need to connect it to an AMP using S-video. I presume I can just use a Scart to S-video/audio lead.
    Is this correct?
    TIA
    Dave
  2. mart.stokes
    mart.stokes
    No, it isn't. The Scart output will probably be either RGB or composite. A Scart to s-video lead does not convert anything and assumes s-video output from the Scart socket.
    You could use an RGB to s-video converter. Try www.rgbtosvideo.com
  3. dochall
    dochall
    Thanks. I'll order it straight away.
    Are there any reasonable faq's on the spaghetti aspect of home cinema? I know the component, rgb, composite hierarchy but things like the above I obviously don't know.
