Got my TIVO a week ago so still learning. However, would appreciate advice on whether or not the TIVO can be programmed to "switch on" an AMSTRAD digibox
I don't own a TIVO but the control codes for an Amstrad digibox are exactly the same as anyother digibox and if I recall correctly the 2.5.5 update allows TIVO to send the "SKY button" code which turns on the digibox before it sends the channel number codes.
