Tivo £229.30 - Go and buy now!
Discussion in 'Digital TV & Video Players & Recorders' started by simon1, Feb 12, 2002.
Tags:
  1. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    Just heard Currys are doing the Tivo for £229.30.
    They even have the latest version - 6023.
    Don't wait any longer!
  2. Big Jim
    Big Jim
    What is different with the new version?
  3. Milhouse
    Milhouse
    Nothing.
    The only reason people refer to 60xx is that this is part of the serial number and although not accurate can be used to give an indication of the age of the box, the number of disks (newer production from about 6021 onwards switched to single disk) and if it has a known problem with NICAM stereo (6020 and before, a free repair is available from TiVo Customer Services).
    Other than NICAM and single/dual disk there is no discernable difference between each of the different production runs.
  4. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    If I bought one, is it easy to add the second drive to these 6023 or will I have to buy an expensive america bracket?
  5. Couch Potato
    Couch Potato
    Nic,
    There's a lot of threads about upgrading Tivo's in particular the "Hinsdale" instructions here
    I think the brackets are inexpensive and some of the UK upgraders have worked around it.
    I've been lurking at the UK Tivo community forum here for a while and will be joining the Tivo community shortly, just got to figure out a way of smuggling the box into the house ;)
    It does look like it's the better option as opposed to Sky+ particularly with the lifetime sub option.
    Steve
  6. GavinBrowne
    GavinBrowne
    Jul 23, 2001
    237
    Edinburgh
    +4
    Hi all,
    Just thought you would like to know I bought a tivo yesterday for £199 inc delivery (next day). It came today as promised and I have just gone through the installation and setup.
    As far as I know it is one of the older versions but I am lead to believe this will actually be easier to upgrade as it should already have 2 discs. Evidently it's fairly straight forward to add a larger disc in place of the second original disc as the brackets are already there. (also gives you the added bonus of a spare disc for the PC)
    I have also read that the nicam problem is not evident when you are using sky digital so for me it should never be a problem.
    If anyone is interested I bought it from mr Tonks who told me they had about 30 left at this price 01922 615212.
    Cheers,
    Gavin.
  7. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Well the deed is done. I have a new 6023 and will set it up tomorrow. I have done a rare thing for me and bought before I saw one working. I hope all you guys are right about this.:D
