Tips on cleaning hdtv LCD screen?
K
KozMix
Anyone have any tips on cleaning an HDtv lcd?
I usually just use the cloth that comes with a pair of glasses and water.
Dampen the cloth and then rinse until drops stop coming from it then use circular motions.
Is that about right?
Also can water seap through the screen? If so how wet would the cloth have to be?
Alot of questions I know but hope you can help, Thanks
Badger0-0
:rotfl:
Yes, you're on the right lines, Kozmix :smashin:
A lint-free cloth is good.
No need for anything special, IMO.
Medusa
When cleaning a HDTV LCD, use a Specsavers glasses cloth.
When cleaning a non-HDTV LCD, use a Boots glasses cloth.
…. And if water seaps through the screen,use Vision Express glasses cloth and wait for 1hour to dry. :D
Badger0-0
I never noticed that part of your post.
You have no worries there :smashin:
A damp cloth is fine
K
KozMix
Love the sarcasm people, thanks :smashin:
Anyways thanks for the info, appreciate it!
