Tiny plasma Sky remote control codes?
Discussion in 'Plasma TVs Forum' started by boltz, Feb 23, 2005.
  1. boltz
    boltz
    Hi All,
    I trawled the net looking for info about how to setup my sky+ remote control to work with my newly delivered Tiny Plasma, how shocked was I to see that just how many people are upset with Tiny's plasmas!!
    Anyway, i followed the instructions on http://homecinema.tiny.com/guides/SKY_insert.pdf
    But none of the codes seem to work, anyone got any ideas on other codes that will work?
    Adam
  2. nealgs
    nealgs
    unfortunately i don't think many people here have had them working long enough to be able to do that even - hence the large threads etc.
    Gary
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Try the tiny tech support line, it's only £1 a minute.
  4. boltz
    boltz
    Please, if you have nothing positive to add, don't add...
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    The point is, that if Tiny's published codes don't work, you are p**ing into the wind. Even Panasonic and Pioneer won't help you with this one. I suspect that sky won't either, they market a competing plasma. It's highly likely that tiny's codes are in fact a semi wild guess. They would have to re-assign a remote code to the screen power command, and as it appears this screen is imported as a kit of parts, I don't think they have the tech resources to do this.
  6. boltz
    boltz
    surely some ONE of the 32,000+ people that have read the post "if you have a TINY plasma then please read" must have managed to get their sky remote working with their plasma?
    I'm well aware that Tiny's service is Sh*te, its taken 2 months to get the damn plasma! :thumbsdow
  7. philip41
    philip41
    Feb 7, 2004
    237
    16
    Sussex
    Sorry but i have never worked it out either.
  8. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    me neither boltz......but are you happy with your tiny otherwise?...i.e. do you not get the shearing etc?
  9. mucca_D
    mucca_D
    Jan 31, 2005
    1,881
    116
    +522
    nope not me either, published codes that came with the screen do not work and the best i could do was to use the learn feature on my nevo :thumbsdow
    I evan tried random codes close to the ones i was given and came up with a big fat zero
  10. Pauldepmanager
    Pauldepmanager
    Jan 10, 2005
    75
    Bournemouth
    i went through every code on my sky remote to try and get it to work with my tiny plasma (sent back and got a refund). Many hours later not one of the codes worked with the Tiny.
  11. Lawyer237
    Lawyer237
    no it does not work.....surprise surprise.
    Lawyer
  12. Enquirer
    Enquirer
    Has anyone tried these codes below they are guesses based on the codes tiny recommend 037 060 065 292 502
    100 104 245 246 285 297 300 304 402 440 521 616 636
    If you have a very early sky box then the Tiny code 502 tiny recommend wont work as this code was added to later sky remotes
