Tiny aerial connector, what type
Discussion in 'LCD & LED LCD TVs Forum' started by jlearmonth, Jan 31, 2014.
Tags:
  1. jlearmonth
    jlearmonth
    May 5, 2008
    612
    +19
    I struggled deciding what forum this should go in so posted here as it's about TV aerials ...
    I bought a TV USB dongle/receiver off eBay from China
    It has a very small aerial socket.
    It came with a portable aerial which also has a very small connector to fit the USB dongle.
    I need an adapter so I can plug in my proper aerial socket.
    Does anyone know what these small connectors are called, so I can look them up ?
    JL
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    A picture would help. Does it have a thread ?
    Could be an SMA connector. Could also be SMB .
    Does it need one of these : DVB T Antenna Adapter | eBay ?
  3. jlearmonth
    jlearmonth
    May 5, 2008
    612
    +19
    Yes thanks, that's the thingy.
    eBay.co.uk search
    Cable Stick Adapter for Antenna USB DVB-T/DVBT TV-Tuner
    0.99p
    I shall order one.
    Might do a quick review of the dongle !
    JL
