Timer recording on Pannasonic E85
Discussion in 'Blu-ray & DVD Players & Recorders' started by keithyboy, Oct 1, 2004.
  1. keithyboy
    keithyboy
    I recently asked Dave 911 on another thread about the Ext Link facility on the above but i didnt want to take over that thread so:
    Dave - you mentioned the following about this facility
    I cant seem to get this to work my connections are the reccommended ones here i.e.
    sky digibox TV SCART > AV2 on E85
    AV1 on E85 > Television
    All SCARTS are RGB enabled.
    In the manual it did mention the Ext Link facility but then says you cant use this with a sky digibox??
    Did you find a workaround for this as it sounds a great facility.
    Now had the E85 for a week and cant fault it - excellent piece of kit.
    keith.
  2. jem
    jem
    Sep 24, 2002
    527
    +7
    The Ext Link function only works if you use the Sky VCR socket to connect to the E85. Then you would lose your RGB recording which is only available from the Sky TV socket.
    Personally I would rather have the RGB quality. My son uses timer record on the E85 along with a reminder set on the digibox if he needs it to change channels.
