snerkler
Outstanding Member
- Joined
- Jun 18, 2011
- Messages
- 23,977
- Reaction score
- 14,261
- Points
- 5,848
Does this mean C-AF will be better then?Nope, Nex6 (poorly implemented), NEX6000, NEX5100, XT1, em1 all also have phase detect on the sensor.
I was asked to take a pic of my colleague for their website yesterday so I took both my cameras, the Sony A77II with 16-50mm f2.8 and Olympus OMD EM10 with 45mm f1.8 and I have to say I think the images look better from the Olly, which I'm slightly upset about. OK so I'm comparing a zoom against a prime, but the Sony combo is £1300 vs £700 of the Olly. I guess using my 50mm prime on the Sony would've been a better comparison but I didn't have it with me
I thought about that but he overall picture looked better, more detail and sharper. However, I did more of a controlled test last night using the Olly with 45mm, and Sony with 16-50mm and 50mm f1.8 as I realised the 'model' filled up more of the frame and so would explain the extra detail.Focal length is probably what does it mate, 90mm looks better than 75mm - 150mm will look better than 90mm etc for portraits! I used to be addicted to 135mm regardless to how awkward it could be!! I.e I want the Oly 75mmF1.8!!
I learn eventually In my defence I only thought it was more important for what I wanted, but then I got that wrong tooGetting right into it now mate!! Good stuff, I remember when you thought a zoom was more important than the sensor or glass Get the CZ85mmF1.4 then your Sony will start dazzling!!
That is one of several lenses on my shortlist tbh, but I think it will be a while before I spend any more money on camera equipment I think the 70-300G will be next, but I also want the 85mm, 135mm and 70-200G. Possibly even the 70-400G. I think I'll be Jim's age before I get that lot though
Which one are you referring to as I listed a few?Save a few quid and get the Minolta or Sigma. Then you wont have to wait as long. +- £450 used.
