Time for a New Amp.....Advice please !?
Discussion in 'AV Receivers & Amplifiers' started by hickmeister, Jan 30, 2009.
  1. hickmeister
    hickmeister
    Mar 4, 2006
    198
    I have had a trusty Denon AVR-1706 for the past 3 years and is still going strong, but with Hi-Def audio and HDMI Switching coming along i think its time to upgrade.
    I have been looking at a few AMPS please see links below
    Onkyo TX-SR606
    whathifi.com - Reviews - Onkyo TX-SR606
    Denon AVR-1909
    Denon AVR-1909 review - whathifi.com
    Sony STR-DG820
    Sony STR-DG820 review - whathifi.com
    Ideally i want
    3-4 HDMI Inputs
    2-3 Component Imputs
    Video Upscaling to 1080p
    Can handle all the various new Hi-Def Audio True-HD...etc.....
    Budget is around.......£300 - £400
    Has anyone got any reccomendations of the 3 above or anymore i havent seen.....?
  2. -=Rob=-
    -=Rob=-
    Jul 21, 2006
    1,781
    48
    +46
    If you up the budget to £499, Richersounds have the Denon 2309 and Onkyo 806 for that money. If you are happy with the Denon then maybe stick with that, or try something new.... I believe the 806 is a big step up from the 606 but not sure how much better the 2309 is over the 1909...
  3. CheesyPuff
    CheesyPuff
    Oct 26, 2008
    98
    Norwich
    +6
    I had the DG 820 for a few months and although very good for the price (£220ish now) I soon felt the need to upgrade and got a Pio VSX-LX51. Although the 51 is out of your price range I'de reccomend the Pioneer VSX-1018AH for £399. It only has two HDMI in but personally i would rather sacrifice an HDMI and have the superior audio.
    I had an earlier Onkyo and it was nice although I would stay away from the Onkyo 806 as I believe it has a problem passing 1080p signals, 606 should be fine.
    Cant really comment on Denon as not really listened to them much but I understand them to be more musical than Home Cinema.
  4. hickmeister
    hickmeister
    Mar 4, 2006
    198
    Thanks for your comments and recommendations...
    Another AMP has popped up when i have been searching around the SONY STR2400ES...see below
    Sony STR-DA2400ES review - whathifi.com
    It gets a cracking a review...if it gets good comments i might strech my budget for this one....
    Does anyone have any ideas if this Sony is any good ???
