Tilting Plasma/LCD wall bracket up to 60" just £20.80
Discussion in 'Shopping, Deals, Discounts & Bargains' started by Oakleyspatz, May 8, 2007.
  1. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,704
    Woking
    +237
    Having just purchased a 50" plasma myself, I discovered how darn expensive the wall brackets are. They average about £150 for a fixed one and close to £199 for a tilting one.
    Save yourself a fortune and visit amazon who are selling this very good quality one for the incredible price of just £20.80!!!!
    Mine arrived 2 days after ordering and came in a nice black colour which matched my Pioneer perfectly. It took me about an hour and a half to put it up and it works a treat. Even comes with a bar to secure the plasma which you can attach a small padlock to so no one can remove it off the wall ( i.e. Burglars!)
    See here for the bargain: http://www.amazon.co.uk/ADJUSTABLE-...2?ie=UTF8&s=electronics&qid=1178660595&sr=8-1
  2. nonsoloinglese
    nonsoloinglese
    May 9, 2006
    1,958
    Kent
    +169
    This would be perfect if it will fit my KDL-40W2000! Any experiences?
  3. mrapbp
    mrapbp
    Dec 28, 2003
    4,958
    83
    Swindon
    +238
    Dont foget the £10 delivery!
    Still pretty good though!
  4. mwallan
    mwallan
    Jan 20, 2003
    987
    +78
    I have one just like that which i got last year for 9.99 and its great, and does the job cant beat it and my plasma is still on the wall
  5. mooomin
    mooomin
    Will this be suitable for a toshiba 32wlt68?
  6. shy1807
    shy1807
    Jan 2, 2004
    81
    Will this work on an internal wall?
  7. wickenden
    wickenden
    Jul 6, 2005
    454
    46
    Bedford
    +115
    9.99 - great deal - where was that from? :)
  8. BSNismo
    BSNismo
    Jan 20, 2007
    10,922
    Waterlooville
    +1,368
    good find there fella,been after one of these 4 my 47 tosh just ordered one myself great find good man for sharing.
  9. FOURSEASONS
    FOURSEASONS
    Feb 10, 2005
    14
    orded my self .recived now the tosh is on the wall great for the price:clap:
  10. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Cheers just ordered one for 32" sharp.:thumbsup:
  11. BSNismo
    BSNismo
    Jan 20, 2007
    10,922
    Waterlooville
    +1,368
    wot size tosh is it uve got was it easy enough to do.
  12. mwallan
    mwallan
    Jan 20, 2003
    987
    +78
  13. rambo13
    rambo13
    May 9, 2007
    102
    +4
    How far do these brackets come out from the wall, as i purchased a similair one from amazon and its 8cm then the depth of the tv (sounds quite far out from wall!!)
    We have the new PS50Q97HDX delivered yesterday but want to get the right mount otherwise hubby will throttle me(i want it to be as close to wall as poss and not to bothered if it has tilt or not as mounting it about 3.5-4ft of ground.
    Please help as i hete making decisions and he says this ones on me.
  14. GrannySmith
    GrannySmith
    Sep 26, 2002
    287
    Pembrokeshire
    +16
  15. jaglad
    jaglad
    Nov 13, 2004
    363
    Hertfordshire
    +20
    I have ordered the bracket from Aria, yes it is not the same as the one shown in the picture, however I have my LG 37 LC2D hanging from the bracket and it is nice and stable.
  16. mwallan
    mwallan
    Jan 20, 2003
    987
    +78
    well it has had my 42phd8 on the wall for over a year and its rock solid esp for the price they were doing them last year
  17. mwallan
    mwallan
    Jan 20, 2003
    987
    +78
    if you want it close to the wall dont get a tilting one.
  18. smashed
    smashed
    Feb 7, 2005
    2,794
    +166
    Does this also swivel horizontally at all? 15 degrees would do me :)
  19. Kev R
    Kev R
    Jul 18, 2000
    538
    Cheshire
    +28
    Tilting or fixed the dimensions stated were the same! including the mounting depth 35mm I think...
    I have ordered the tilting one just cos it was cheaper for some reason, don't need the tilting one cos I am mounting my 42in panny low down. If it holds it on the wall for that price I will be well happy.
    I think I may eventually recess mine anyway 125mm from wall to glass front including the wall bracket isn't too bad.
  20. KevinWood
    KevinWood
    Dec 9, 2002
    102
    19
    Stirling
    I bought two of these, one for my 42px70 and one for my 50px70 and I have to say I was well impressed. Having over the years bought various wall brackets (which in reality were just big chunks of metal!) for over £100 quid with holes that didn't even match up with my Plasma's, these have all the bits you need to connect to your plasma as well as being rock solid when on the wall - at this price they really are a bargain.
    Kevin.
  21. MChatterley
    MChatterley
    Dec 6, 2006
    1,804
    Droitwich, Worcestershire
    +81
    Anyone any ideas on this? Need to pop a 26" LCD on a crappy plasterboard based wall with solid metal raw plugs.
