Tilting a Toshiba
Discussion in 'General TV Discussions Forum' started by jjenkins, Mar 19, 2002.
  1. jjenkins
    jjenkins
    I need to move my Toshiba rear projection to an upstairs room, the problem is I will need to tilt the TV to get it up the stairs and under the landing. Does anyone know if this will cause any damage to the TV? I wonder as when it was delivered the people doing so, said it shouldn't be tipped! Any Help always greatfully recieved. :confused:
  2. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    I'm sure that the best advice is to keep it vertical at all times, but I also know that I transported my RP Toshiba several miles in the back of my car laying flat without even disturbing the convergence so it is not necessarily a problem.
    I guess that avoiding physical shock to the set is the most important thing rather than just orientation.
    Mark
  3. jjenkins
    jjenkins
    Many thanks Mark,
    That was just the news I was hoping for.
    Must remember not to drop it ;)
  4. shaunthedude
    shaunthedude
    yip, mine was carried on its side up the stairs. Its fine.
