Question Tilt centre speaker
tigermad
I'm looking for something cheap and cheerful to tilt my centre speaker up so the sound is directed more at my head. What do people suggest I use? Was looking at mopads but I don't want to be able to see it. I will be using it with a MA bronze centre. Thanks.
Jase
As above. You can cut a MoPad (or the equivalent version from Adam). Alternatively, just use the extra foam sections that are included rather than the main base. You'll still see part of it as you need to get the pads under the front edge of the speaker or it won't be stable enough.
Dolus
Rubber doorstops, felt pads, stick on rubber feet, thousands on ebay.
self adhesive rubber feet | eBay
or don't spend the money and use £1 coins to tilt the speaker up. :D
Dolus
ahem..........that is spending the money, n'est pas?
No just a loan. If you buy something to tilt the speaker up, then sometime later decide not to use it, it usually goes into a drawer never to be seen again. Now with £1 coins you can go buy an ice cream. :clap:
