Tiger Woods 2005 problems (Xbox)
Discussion in 'Xbox Forums' started by common, Sep 27, 2004.
  1. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    Anyone else having problems with TW2005 ? I cannot get the thing to run on my modded xbox either from the HD or direct from the disc
  2. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    have a check to see if youll need a hard drive fix for the game, this might solve running it from the hard drive.
    not got a clue why it wouldnt work from the dvdrom
  3. broona
    broona
    Aug 26, 2004
    5,625
    Hexham
    +689
    Have you got the Pal version? If so, you need to set your Xbox to Pal in the dashboard, it locks up while loading on an NTSC machine (or a Pal machine set to NTSC in the bios). :)
  4. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    Broona, you've sussed it ! cheers mate
  5. broona
    broona
    Aug 26, 2004
    5,625
    Hexham
    +689
    Excellent! There's an NTSC patch for it over at Xbox Sky (do a Google) to save you keep swapping over between the 2 standards, works great too.
    PS, am I allowed to put a link to a torrent site, didn't just in case?!
  6. boingboing
    boingboing
    May 13, 2004
    628
    28
    Droitwich, Worcestershire
    +25
    What an idiot am I ?
    I looked at a couple of reviews and it said Xbox Live. Fantastic I thought, so ordered it from Play.
    Arrived on Saturday and no Xbox Live! So again I looked on the internet and found a page saying that it is only going to be Live in USA. Is this because we whopped them in the Ryder Cup? and they didnt fancy the jibes?
    Shame.
    Pete
